1994 J30t Idle Problem
Ed.
Hey guys,
New to the board but was recommended by a guy from my Lex board.
My aunt just got a Lexus SC so her J30 (use to belong to my dad about 7 years ago) is now the spare car for anyone in the family to use. Infiniti had some problems though and the main one was the idle. You come to a stop in that thing and its like your in a dragster. Before I set up an account I was reading a post about an idle controler that is possibly bad? She also uses mid-grade so Im thinking that has caused problems to the car over the years as well. What is there to check for right away with the idle though?
Also the radio is out. This happened to us when we owned the car years ago and we took it to the dealer and they fixed it and sent it back. Do you think the same thing has happened again?
Thx for the help and look forward to posting here!
Pogophil
If the car is throwing a code, that would help. If not, it could be a number of things related to air or fuel. It could be the MAF, the ICV, the injectors, etc.
These radios are pretty unreliable. If you're interested, I have a spare radio for you.... Maybe we can work something out. PM me if interested.
Good luck.
yodawill2000
Car: 94 Infiniti J30
Years of less than premium gas would definatly be an issue.Run some BG44k through it with a tank of premium gas.You will want to change the oil out afterwards FYI.
Ed.
Thanks for the info guys! I would love to have this car as a daily for my BMW but odds are that wont happen for awhile so I would like to fix it up in the meantime.
Its a '94 so what would be the best way to get the error codes for it? Im gonna be out where its at this weekend and could run it down to Autozone and see what they say.
Pogophil its me Ed from bimmerboard! I knew your name looked familiar I need to update my sig for this place. Im gonna call the palce we went to just for laughs and see what they say about the radio. Just out of spite you know and if they dont want to do anything Ill see if someone wants to help pay for it. I would but since Im not driving it screw those guys! No Im joking. I honestly want to take it from my other aunts house and bring it home with me!
yodawill2000
94 is a odb1 Autozone usually cant read those You can yourself though.Here's the how too.
http://www.nicoclub.com/articl...shtml
Ed.
all right. thx man! ill print this out and take it with me this weekend and give it a try. I know she had two of the injectors go bad and something belt related went out when we had the car once. Im not sure what though. All I know is that it has caused a belt screech ever since and no one can seem to fix it!
gr8scott72
Car: 1994 Infiniti J30t
Ed. wrote:all right. thx man! ill print this out and take it with me this weekend and give it a try. I know she had two of the injectors go bad and something belt related went out when we had the car once. Im not sure what though. All I know is that it has caused a belt screech ever since and no one can seem to fix it!
Belt screech = loose belt. Probably the alt belt.
Ed.
she says they took it in three times and its "as tight as it can be." i dont really believe that though. if it makes sense she says its worse with the ac on when you start the car..?
Pogophil
Ed. wrote:she says they took it in three times and its "as tight as it can be." i dont really believe that though. if it makes sense she says its worse with the ac on when you start the car..?
Ed! Good to see you here -- welcome to the board. I should have recognized the name the first time -- I see you all over Bimmerboard these days.
Loose belts are more prone to squeal at startup when the car is cold. Given that it's worse when the AC is on, it's probably the AC belt (which may also be the alternator belt as mentioned earlier -- I'm still on the learning curve myself). Sounds like it needs to be tightened. Same thing was needed on ours.
Good luck.
Ed.
Im runnin things over there No Im jokin!
Oh ok. yeah its real annoying. Almost as bad as the transmission on my 97. Almost.... lol
Im gonna get to work on it this weekend and see what codes I can pull and waht to do about that ide. Thanks again guys for all the help!
littlewillie
Modified by littlewillie at 11:37 PM 12/23/2007
driverdriver
Car: NICO's longtime resident Canuck!!!
Welecome to NICO Ed!!!
Ed.
hey willie-you know i was looking at the engine bay a few weeks ago and noticed a ton of oil around the egr valves and stupily thought nothing of it! same thing as you though her CEL would come on and off. Where is the best palce to get them from? Thx!
hey dd! thanks! i cant wait to post here more and help out as much as i can! the J is a great car adn i enjoyed all the years we had with it.
Ed.
D'oh! Not the EGR, I meant the PCV valves were the ones I saw! They had oil all over them.
littlewillie
Ed.
thx again willie!
gotspeed
Car: 96 nissan pathfinder 97 infiniti J30
hey did you check for the codes on the computer? Some sensors on our car go bad and they don't throw a check engine light, so you need to pull them and see what you got.
Ed.
not yet but id like to today if i have time! im gonna be out where the car is so im gonna try and sneak in a a few seconds and see whats goin on! hoopefully they are good but im guessing not! lol
