SymptomsKey fob not locking doorsUsing key drivers side lock sometimes will not lock up properly when using key outside.When locking using interior latch or using key from driver's side or passenger side.The exterior driver's and passenger side key hole lights stay on as well as the light around the ignition light. The other interior lights dim as they should.I replaced the driver's side lock actuator didn't help.
Any advice would be greatly appreciated!
Can anyone tell me how to change out timer contro unit it seems to be the issue dome light and ley hole lights not shutting down
Modified by Joedude30 at 3:36 PM 9/16/2008
