RocketCityJ30 »
https://forums.nicoclub.com/rocketcityj30-u44892.html
Sat Feb 10, 2007 12:37 pm
I know that this topic has been discussed in some detail here, but now it has happened to me. Driver's door is locked. Power or manual (inside or outside with key) will not work. Disconnected the battery to take the power locks out of the equation, but it will still not unlock manually. It feels as if the rod starts to move the lock mechanism, but not enough to get the job done. Tried the "bang your fist to the rear of the door handle" trick until I about busted my hand with no results.
I have seen some anecdotal information on the site that one person used a slimjim successfully, and one got enough of the interior door panel off to get to the lock mechanism to unlock and open the door, but no specifics.
So, if there is anyone out there that has successfully accomplished getting the door open without destroying either the inside or outside of the door/panel, please respond in detail how you did it.
Thanks,
John
