Q45tech wrote:Yes, please post how and on what you have spent the $5,000 over previous 2 years [30k] in mainteance and repairs.
Seeing as how it is his first post, have you considered the possibility that maybe this is his first issue with the Q? Maybe he just bought it and doesn't have that information? Maybe the first time it happened and then went away, he wrote it off as a fluke?
Q45tech wrote:Sounds like the ecu is in fail safe mode due to a missing signal from 1 or more sensors. 'MAF" and or "CAS"................................but then again a worn out fuel pump can limit top speed and acceleration.
At least that gives him some different routes to take. Would have been really helpful if you gave him the link to the FSM so he would be able to take a look. Throwing acronyms around to someone possibly unfamiliar with them doesn't help.
morton27 wrote:The story goes my wife was driving the car this morning and it would not go aboe 25 mph andthen it stalled. Started back-up and it got her home. Of course, just the night before I drove it with no problems. This is the second time it has happened to her. What should I check? Thanx for any help
Morton27, here's a link to the Factory Service Manual for your Q's model year. This is the same guide that the Infiniti Techs used at the dealership. It has some flowcharts to help you isolate the problem as well as instructions on how to fix it. It's in .pdf format (Adobe Reader) so it's easy to view on your computer. Hope this helps.
http://www.nicoclub.com/FSM/Q45/1994_Q45/
