1994 Infiniti Q45 Active Suspension
blackeagle113089
Car: 94 infiniti q45
I have a 94 q45, had to previous owners before me. I was takin a look at the suspension the other day and noticed there are some slow leaks, im not sure exactly where their comin from but its only leakin on the drivers side front and rear. What would you say is the problem for the leak? It is the active suspension fluid leaking I do believe. The ride isnt as smooth as it should be. What would be the cause of this and need to be replaced? Another question is when the vehicle is on and sitting in park, the active suspension starts going up and down and wont stop until i restart the vehicle.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
welcome to the home of Q45. please tell us more about your car's history. get the infiniti service records if you've not already done so. You'll find lots of active info from the user 'texasoil' he is the guru of the actives. as an active owner i can tell you that: the going up and down you describe is an instability in your system. could be caused by lots of things. look in your fsm for how to run the active self-test. report the codes, check the fluid level, make sure it's on the high side of the 'full' line (but not up to the top of reservoir). does the active make any noises?
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
Just saw your post. Drop me a line ([email protected]) and discuss where you are.cell # (832) 651-7576
