What? Do you mean you don't have one of these :
I'm just teasing. I wish I did.
goody90q45 wrote:The difference between the valet key and the main ignition key is the square slot in the shaft of the key. The valet key doesn't have it but the aftermarket blank you can buy on ebay does.
The Valet key uncut
goody90q45 wrote: Once you have a blank find a locksmith that's invested in the $5000 cutter that's needed to make the key and for another $30-$40 you'll have your spare.
You can call the person Heath recommends if you want to go aftermarket:
Q451990 wrote:McLock Locksmith(864) 934-3411 or (864) 231-9671E-mail:
[email protected]
I have been told that he can do magical things, like cut keys from a faxed copy of your existing key - but I don't know if that's true or not...
Heath
If you decide to go oem, you can order a new key based on the key code for you car. If you choose to go with an aftermarket key like Ilco (from eBay for example) it will look similar to this:
If you want an oem here are your choices if they are still available:
If you are extremely lucky you might be able to persuade Wes into selling you his prized possession:
