1994 heater issue
hst
Car: 1994 Q45, 1994 BMW 325I
I just got my Q a few weeks ago, and love every min. of it. Yesterday it got cold and I found need to turn on the heat. And to my suprise, it was not working.. I turned off the radio and heard a bubbling type sound fron behind the dash. I'm thinking that air is "stuck" in the heater core, thus no heat. I left the her on for about 10 min or so, but it did not get any better. How can I get the air out? Or is there something else wrong here??
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Probably, but who knows if it is air in the heater core or a faulty heater door? Did you change your coolant fluid lately?
Might post in Infiniti Online Mechanic with a brief recent service history where most of this information is located.
Modified by maxnix at 7:27 AM 3/21/2006
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Its probably a heater door.. Even in my Q which has a well maintained and clean cooling system i hear the gurgling, i think its normal to a certain extent.
Q45tech
When the radiator cap is not oem or fresh.........air gets in some times on cool down.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:Even in my Q which has a well maintained and clean cooling system i hear the gurgling, i think its normal to a certain extent.
Never heard it on any of the dozen or so Q45 I have been in.
hst
I had heard about the radiator cap being bad, I will replace that. The noise I can live with, not having heat is another story.....
Q45tech
There is a NICO thread on do it yourself repair or we [T3 -ATL] can do it [replace door] for under $1000 [takes an entire day 12 hours]..........get quotes from local and Chattanoga dealers.
Not something techs like to do because the good ones can bill 14-15 hours in a day with multiple jobs.
nuQ
Car: 2003 Infiniti M45
2009 Dodge Caliber SXT
just had the exact same problem a couple months ago! my radiator cap was bad and alot of my coolent leaked out. because the coolent level was so low i also heard the gurgling under the dash and had no heat. i did a complete flush and fill and got a new radiator cap. all is well!
I've heard it on maybe 1/3 of the Qs I've driven (a little over a dozen), including my last one.
To get rid of the air, I put the front on jack stands, opened the radiator cap, and let the car warm up while revving it a few times. Sometimes coolant would splash out, and I'd continue to top it off; apparently this helps to remove air pockets. I learned how to do it from a Nissan tech on NICO in an old thread, and it worked nicely.
I prefer Chrysler's method of offering a simple bleed screw.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Seems like that old TSB about coding the heater open may apply here, but I thought there is no valve to the heater core. Guess I'll have to dig it up.
