eric.g90 »
https://forums.nicoclub.com/eric-g90-u219863.html
Fri May 10, 2013 7:13 pm
Hello all. I am new to the forum. I have a 1994 Hardbody (3.0L V6, Automatic, 4WD) that is leaking oil on the front right hub. It looks like it is leaking from the outer part of the hub near the hub cap. I haven't replaced any seals in the hubs since i bought it a year ago. It has 322,500 miles on it. I have 2 questions; will it be ok to drive it in 2H until i get it fixed (I have read the Haynes and it doesn't appear to affect the bearing lubrication)? And, assuming it is the seal behind the cap, will it be an easy fix? Thanks in Advance.
