1994 G20 Someone please HELP!
Post all your Nissan electronics, car audio and stereo questions here!
vic3038
My front speakers haven't worked in over a year and I've finally decided to do something about it. I have a '94 G20 with the active speaker system. ( I have no idea what that means) I was able to figure out that the reason my front speakers don't work is because I installed a JVC El cameleon deck which blew the amp for the front speakers. There are two Clarion amps under the rear deck, one for the front speakers, one for the back. My question is can i just buy some regular amp to replace the blown one or would that take more wiring or something more that I would rather not deal with? I would like to do this myself if possible, I'm not too experienced but I can do simple wiring. (Installed the deck myself)Thanks a lot
maxI30t
Car: videogames, cars, girls, and money
so are you sure its the amp and not the speakers? well if thats the case...from what i'm reading you could just replace the amp with alittle wiring.
vic3038
it's definitely the amp, i checked to speakers. Do i just buy a harness for the wiring, b/c the wiring going into the amp is one big plug with different wires going into it or do i just cut it off? also i've read a lot about power supply, is one of the wires there for the power or do i have to run a new one?
Simmsled
Car: TSI GTI - E46 325i
If you have the JVC deck in there, just bypass the amps. The on-board amp in the JVC will power your speakers. If you want it to be amplified beyond the power that your JVC offers, you will need to go about it another way. What do you want to do?
maxI30t
vic your better off doing it simm's way. because replacing an amp...especially a stock amp would mean alot of time wiring. sorry for misleading you earlier i thought you had some small aftermarket amps. replacing aftermarket amps is a lot easier than stock.
vic3038
I would simply like to get my speakers to work. If I could do it bypassing the amp that'd be nice. I just have to figure out how to do that.
A_Rivers
Car: 1998 Honda CRV, 1996 Yamaha FZR600
Hey Vic, Simms is correct about bypassing the factory amps your JVC has an onboard amplifier so there is no need for aftermarket or factory amps for that matter, now I'm not 100% sure about the system in your G but there should be one plug going into each one of the amps in the back, in that plug your going to have about 10 wires 8 of those are speaker wires the others are power and remote turn on(the amp is grounded thru the frame). I will give you an exaple of rewireing the rear speakers in my Active Speaker equiped '91 240SX. The right speaker has 2 wires going into it from the amp a Blue and a Blue Yellow, the Blue is the positve and the Blue Yellow is the negative. Now all you have to do is find out which wires are coming from the head unit for the right side. In my car they are Purple and Pink. Now cut the Purple and the Blue Yellow wires and splice them together. Do the same for the Left channel (Brown and Brown Yellow speaker and Green and Red for the input from the head unit).
vic3038
Success! thanks a lot guys. I bypassed the amps in the back and it works just fine.
PalmerWMD
Car: 2004 350Z
Good job guys!
Another Nissan/Infinti healed!
To the Batmobile
Fred...:batman
