Silvia2b »
https://forums.nicoclub.com/silvia2b-u2470.html
Wed Oct 08, 2003 11:36 am
I'm not sure where the front amplifier is, but there are at least two posibilities one location could be in the dash beneath the radio mounting location. The front amp could also be the clarion round hockey puck shaped thing mounted under the rear deack and the rears just run off the deck power. You have the front tweeters in the A-pillar right? Do the rear speakers play when there is no remote turn on connected? If so that means the rears are non-amplified check to see if the amp in the back is for the fronts. the colors for the drivers door speaker are blue/white +, and red/ blue -, and for passengers it is brown +, Brown/white -. Look for these wires coming out of whatever you suspect is the amplifier. sorry it's been a while since I worked on one, and they've all been different model years, with different systems.
