1994 g20 A/C only works on high (#4)
newTechGuy10
I have a 1994 infiniti G20, and recently this happened, where the A/C only works on High (#4), I had an earlier post and I did not get any responses, i am hoping someone can assist me with this. I replaced the climated control unit, the fan blower and the resistor(not sure if this is the name though, but its found next to the fan blower) and still no use. A friend mentioned something about a relay but I have no idea what it is and where its found on my car....Please someone assist me.Thanks
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Do you have the FSM?
http://www.nicoclub.com/FSM//
newTechGuy10
Thanks for the reply, however, the FSM documents only show how they work, they do not address if there's an issue or if something is not working. I am still stuck with no solution...please someone advise.
goody90q45
Car: 1992 Infiniti Q45 (sold)
I'm not sure about the G20 but the Q45 has a fan control amplifier which when faulty will only allow the blower to run on high speed no matter what the setting. Check out the pic I attached. If the G20 has this amp it should be in a similar location behind the glove box.
newTechGuy10
Thanks for the reply, however, next to the fan blower i have changed a resistor and I am not sure if thats what you mean by amplifier...i will check and hopefully that works....once again thanks for the post.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
It's not really a resistor but a Darlington transisitor bridge.
If you are serious abuot working on this car, download the TSB at
http://www.nissan-techinfo.com/infiniti/
for a one day $20 subscription.
Doesn't G20 FSM have trouble shooting diagnostic procedures like other Infiniti FSM?
jtesensky
Vendor
Car: 2005 Infiniti QX56
2002 Infiniti QX4
Have you replaced part number 27150-62J60?
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
Joe! You post?!!? :D Good to see.
jtesensky
Vendor
2002 Infiniti QX4
AlabamaDan wrote:Joe! You post?!!? :D Good to see.
Not enough! But Ill keep after it...
