1994 Blacktop ECU question
Silviata66
Car: 1992 Mazda Miata with a S13 blacktop
I've been searching around quite a bit for any info on the compatibility of the #62 Redtop ECU on my 1994 Blacktop motor with an OEM wiring harness. I have been swapping over my Miata to an SR20det, and I'm down to needing an ECU that is stock, and a FMIC. What is the downside of using the #62 ECU instead of the E5? because I cannot find an E5 for sale ANYWHERE. thanks in advance, and I apologize if someone knows of a direct link to answer this question.
duffman1278
Car: 89 240sx Hatch, the wildcats!
You're sigs HUGE, are your sure thats within the limit?
SpeedRacer1
Car: 1990 240SX, G35
Redtop ECU's will run blacktop S13's fine. The O2 sensor may or may not work.
Silviata66
Yeah, my sig was too big, just deleted it. thanks for the advice, should I use the 2 wire redtop O2 sensor?
SpeedRacer1
No, heated is fine. The pins on the ecu are where in different places.
