Timothy S »
https://forums.nicoclub.com/timothy-s-u242199.html
Sat Feb 21, 2015 1:33 pm
On My Altima there are two thermostats, one, a mechanical valve that allows coolant to flow to the radiator and another, an electrical sensor near the upper radiator hose that operates the gauge on the dash. The coolant thermosat should not cause the engine to die, even if it were malfunctioning. you can test it in the car by feeling the upper radiator hose to see if it gets hot when the dash gauge is about 1/3 up from cold. The thermostat opens around 170F. However, I was thinking more on the lines of an electrical problem.
When the car dies, you want to check for spark (a timing light or spark tester works for me) and fuel to the cylinders (smell the exhaust or use a fuel pressure gauge at the fuel injector rail). If both are present the mixture is off. But if fuel is not getting to the cylinders you have an ignition switch, fuel pressure, or injector issue.
One more Question: Does the car die at an idle when hot, or will it die while driving with your foot on the accelerator?
