1994-96 Q45 fuel injector tips
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
I have a fuel injection assembly from a 94-96 Q45 that I am going to be swapping onto my car. The problem I have is that some of the plastic rings that surround the tip of the injector nozzles are broken. They don't seem to hold the tip on so I was wondering if they are necessary for the function of the injector? I know that they must have served some purpose but if it will not affect the performance of them then will it be ok to install?
Q451990
I'd check with www.deatschwerks.com and see if they can shoot you a set. Like you said, they must serve some purpose...
Also saw these. http://tradergreg.ecrater.com/p/1199119 ... tor-pintle
Heath
