1994 300ZX STALLS
nrjmarine88
Car: 300 ZX
I just purchased my son a 94 300zx non-turbo version. While driving, it will just completely shut down. It seems like a an electrical issue of some sort. All dash board indications display like the key is in the on position prior to starting. He coast to the side of the road and starts it right back up usually with no other stall, anytime soon anyway. Any ideas what might be causing this or where to start looking? It is his first car...YEAH...
300ZXttZMAN
Is the car automatic or standard?
How well does it idle when its just parked?
Also I am moving this the Z32 tech section so that everyone can help. :bigthumb:
nrjmarine88
Car: 300 ZX
I am new to this so bare with me..Thanks...It is a standard...I need to put a clutch in it as well once I return from deployment. I recently had to replace a few power steering hoses but not the high pressure one. There was some leakage from the line onto the alternator but it did not seem to affect the charging system, I think.
nrjmarine88
Car: 300 ZX
It starts fine and idles normal...
300ZXttZMAN
Hmm beats me. Lets see what the others have to say.
canadian booster
Car: 1993 Nissan Z32 TT JDM
one sec, i didn't read the whole post, doh, fail me
300ZXttZMAN
canadian booster wrote:one sec, i didn't read the whole post, doh, fail me
:chuckle:
Is there a difference between how it drives when its fully warmed up vs cold?? Or does it just stall all the time?
nrjmarine88
Car: 300 ZX
No not really...It doen't even stall all the time...I need to see if there is a pattern in when it does stall the first time. It really runs good as long as it continues to run...I am leaning towards a ignition issue...I don't know much about the ignition system but it is almost like something might be loose...My first thought was a thermal issue but it starts right back up with no issues...Any ignition guru's out there want to add something about that?
nissanfreak12
Car: 92 300zx 2+2 TT
Im thinking more wiring issue. How are the connectors to pretty much everything?
DarkstarNovermber
Car: 94 Slicktop Z
This might seem kinda obvious, but are the battery connections on tight? I remember the same exact thing happened in my 240 and it was because the negative cable was loose and momentarily came off after hitting a bump.
nrjmarine88
Car: 300 ZX
Yes, that was one of the first things I checked. Since the battery is used to complete the circuit these days it was the most obvious choice to first look at.
worldisgrand
Car: 1990 300ZX TT
Does it stall when coming to a stop or just in the middle of driving down the road? Speeding up or slowing down?
nrjmarine88
Car: 300 ZX
Just driving down the road. No particular accellerating or decellerating operations that I can put my finger on.
es.biggs
Car: 1990 300ZX 5sp NA
AC on or off? Does it seem to make a difference?
es.biggs
es.biggs
