I'm really wanting the car to be as comfy as possible and a good daily driver. Reliable and just fun to go drive around in.
Anyways, I got the car 6/7/2013 after the guy said he would take a lot less for the car since it wouldn't go into gear, and that was on may 30th. So i sold my 240sx vert and went to go get it. It looked a lot better in person than it did in the pictures he had sent to me, so i was even more excited to get it and bring it home, it even had the wheels i wanted on it until i save up for some nice ones too.
So here are the pictures of it the day i got it.
The car is NA, 212k miles, and doesn't smoke one bit. Looks like the previous owner has taken it somewhere to get the timing belt done at 199k and the oil changed at 212k from the stickers that are under the hood/on the windshield.I don't know how safe i feel about the belt so i may end up replacing it so i know its new.
So i got it jacked up and took the transmission out
Getting to the top drivers side transmission bolt proved to be rather difficult... so me and my dad made a huge extension and it worked.
I had a feeling the problem would be the same problem i had when i had my hatchback 240sx... One of the springs in the center of the clutch popped out somehow.
So i have a new clutch ordered and now i'm waiting for it to get here.
I also think my rear seal may have a leak and i think would be worth it to go ahead and replace now while its easy. so i'll probably go to the auto parts store tomorrow and pick one up.
You can also see the oil on each side of the block from the valve covers leaking.
And while the exhaust is off i thought i would at least clean it up and make it look a little bit better until i get an aftermarket exhaust.
