car nut »
https://forums.nicoclub.com/car-nut-u145197.html
Mon Jun 21, 2010 4:35 pm
Well, the torque is great but honestly, I'd rather just have a twin turbo. It's only a little bit more expensive and everything fits together perfectly. Plus it's a lot easier to sell a TT then a frankenstein car.
As far as what I had to do, this is what I can remember off the top of my head:
-Modified Z32 crossmember (uses stock Q45 mounts)
-Mazworx VH->VG transmission adapter
-Custom radiator w/electric fan (no room for mechanical fan)
-Re-do wiring harness (not too bad there's some write-ups on it)
-Walbro 255lph fuel pump (TT is better but much more expensive)
-Custom exhaust
-Re-routed P/S lines
-Life without A/C
I used a TT clutch/flywheel combo so I also needed a starter spacer. It's a lot of work and there's barely any aftermarket support for the VH45. Also, the motor and intake (routed beneath the driver side headlight) take up the whole engine bay so if I wanted to turbocharge I would really need a remote mount setup. It's a fun nimble car but a TT has a much greater potential and I'll never be able to sell my car as a whole.
