240femme »
https://forums.nicoclub.com/240femme-u10804.html
Sat Nov 19, 2005 9:50 pm
My car has a tendency to have intermittant problems, and this time it's no different. This problem is slightly different than others of its kind, so I felt it deserved a new post topic. Here goes:
My car is overheating, but not really - let me explain. With no prior symptoms, it got very close to the red zone temperature-wise. I was driving home from work and had probably only gone two or three miles (city driving). I noticed the needle was way up, and pulled over to look things over. I put my had very close to the top of the engine and didn't feel much heat. I then placed my hand, palm down, right on the engine. It was barely warm. I should mention that I replaced the coolant temperature sensor replaced this year, so I figured that probably wasn't it. I've also replaced the radiator, radiator cap, thermostat, and water pump all within the last 18 months. I would think all those things would be okay. The oil's fine...coolant level was a little low, but I fixed that. Anyway, on with the story. I figured since I was half a mile away from home, and the engine didn't seem hot, I could make it. The needle actually went down and back up again while driving. It actually seemed to go down once just when I went around a turn. The air from the heater would also get hot, then cold, then hot. I know an air bubble can cause this sort of trouble, but I haven't had any work done to the coolant system lately. It seems like the air bubble issue only pops up after cooling system repair/maintainance. Is there any other reason a bubble would be there? I don't seem to be leaking coolant. Another thing that concerns me is that I was able to place my hand on the engine and hold it there. I was going to work on it today, but now I'm having alternator issues and don't want to drive and get stranded somewhere. Sorry for the long post, but I think sometimes a story of the breakdown speaks volumes when trying to find an answer.
