Jaycastro96 »
https://forums.nicoclub.com/jaycastro96-u271932.html
Wed Feb 15, 2017 8:04 pm
2 days ago I was checking the spark plugs, I put them back on and the first cylinder spark plug was tightened too much so it bent the gap close I knew because the car was misfiring, so I took it back out and opened the gap on the spark plug then it fired up back normally after , to check the spark I pulled off the spark plug wire while it was running and it was sparking till it was away and out of the hole, as soon as I pushed it back in the car turned off, if anyone knows what possibly could of happened here please let me know , and thank you.
