As soon as I found the right car, I fell in love with it.
Purchased June 29th, 2011, it was the 91st car off the line that year (According to sequence number)
All stock, with some not so hot looking wheels on it.
Here's the day I took it home from sitting on some guy's property for a year.
178545_10151001881875970_1685306109_o by todd5854, on Flickr
201463_10151179683205970_1456400073_o by todd5854, on Flickr
Repaired the behind the license plate rust
336329_10151017946340970_2089486115_o by todd5854, on Flickr
Now, to work..
First thing I did was buy a manual transmission. Yes I fit it in the trunk haha. I will be going KA-T, because I like torque. A lot of it. But I want it to be a reliable daily.
56270_10151213355160970_1917843029_o by todd5854, on Flickr
As my room piles up with racecar parts, I get closer to starting the swap.
78153_10151220054380970_330883239_o by todd5854, on Flickr
I had some extra s13 coupe tail lights laying around, so I decided to tint them, that way I kept my original parts unmodified.
57894_10151208351615970_989575993_n by todd5854, on Flickr
Here's my engine bay with the new intake manifold installed, strut bar, and terribly awful painted valve cover, will be redoing it as soon as it's warm again.
53456_10151222570580970_944399620_o by todd5854, on Flickr
Then I bought some new Function and Form Type II coilovers.
665901_10151223836140970_1103724282_o by todd5854, on Flickr
LITTLE HEADS UP if you plan to drop your s13 convertible!
This is the rear strut tower, behind the rear seat. My shock dampers hit that brace.
Untitled by todd5854, on Flickr
Let's whip out the die grinder and fix that...
I noticed my front left fender wire harness was rubbing.. I noticed when I almost got stranded because stuff kept shorting out.
This one took a little while to fit correctly..
Cut a few slits here and there to properly fit the harness. Notice I left something to tie-wrap it to.
Here it is all done, ready to be put back together. I hammered an indentation into the rail, to better fit the harness. Otherwise it will make putting the fender back on a project too. While you're under there grinding stuff out, be sure to coat it in some kind of paint. I used self-etching primer and then I painted it all gloss black.
This shows the harness in its new spot, if you look to the left you can see the original location, with the cut clip. Haha
So, I definitely love my s13 convertible.. can't wait to get rid of those nasty wheels, roll the fenders, and give it a proper paint job!
Here's my friend's s13 hatch, and my other friends s14.
The s13 convertible really is a unique car, there are so many things that can be done to it to enhance the performance! It turns heads everywhere with the top down.
