95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Wed Apr 23, 2008 5:22 am
sounds like maybe not air in the lines, but stuck caliper slides or pistons. when that happens, early on, the piston(s) or slide(s) that are stuck will stop sticking seemingly at random, but more likely when they experience a very large force (like one good mash of the pedal). i would go get some brake caliper grease and go lubricate the heck out of your slides, and check your caliper pistons while you're down there. if they're very difficult to turn (turn by the slots, don't grab the outside if it's sticking out a little!), you can either rebuild the caliper(s) for probably $5-$10 each affected or go to autozone and get freshly rebuilt ones for probably $30-$40 each.
