qsiguy wrote:I've never tried it so I wouldn't say it won't work. The 90-93 ecu works in the 94 so it's a safe bet it would work the other way around.
The ECU programs are nearly identical so there would be no benefit I can see to do this. The only reason we use the 90-93's in the 94's is because the 8-bits are easier/cheaper to mod.
The Actual ECU's are switchable from a 1990-1995 Q45 Yes. But the internal software may not be like Carlos said, which makes a lot of sense.
But if what Shane says is true then it must be the hardware that makes the 1994-1995 Q45 ECU superior.
How would the NICO ECU program be affected if it ran on a 1994-1995 Q45 ECU?
