DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Tue May 21, 2019 9:24 am
The rear seal is most probably your issue since you said you've replaced valve cover gaskets, both of my cars had the same small drips that increased over time but both had trans service done at some point and where the rear main seal got replaced, and drips ceased. Both cars also had valve cover gaskets done, the lower heads are notorious for leaks as well as that rear seal.
Most likely a heavier oil MAY help some with the number of drips, but a bad seal is a bad seal and they are cheap in the grand scheme of things so replacement is obviously the smart choice.
