Jott5555 »
https://forums.nicoclub.com/jott5555-u32428.html
Sat Jul 22, 2006 7:45 pm
So i pulled my upper mani off to put on a direct port nos kit, everything went well, after i got it all back together things ran well, today about about 101 and i noticed while sitting at a light my temp gauge was at HIGH totally pegged.. so i pulled over things under the hood were fine no smokeing or anything
so i got back in cranked the heat on and turned the ac on even though my condensor and pump are missing i hope it would turn the electric fan on. so then everthing went back to perfect.. i got home noticed the coolant was low some air bubbles escaped my bleeding, so i filled it up.. on another outing same day i notice the temp is back pegged at high so i turn on head and ac again things go back to normal so i took a chance and turned them off and it stayed at normal for the remainder of my drive (10 min or so throught town)
another thing i noticed is when the gauge would react VERY fast after fans went on it would take less 5 seconds for it to return to normal after turning the fans on, the coolant is full and new so im kinda stumped.. and there was no issues previous to the install and i have yet to use the NOS because of an empty tank..
