1993 sentra se
nastynate
Car: 1993 sentra se
I have a 1993 sentra se and I was wanting some tips to add muscle? What's the best mods to beef it up? Or should I get a sr20de and start there? Any help from anyone? I just want to make it truly nasty.
audtatious
you can throw a turbo on it. To make it really nasty then rebuild the motor for turbo with forged internals and put a Pulsar AWD package underneath it. Lots of work and expense but it could be a nasty ride.
nastynate
Car: 1993 sentra se
So pretty much just rebuild the motor for turbo? Or would it be easier and cheaper to throw a different motor in it?
nastynate
Car: 1993 sentra se
Where is the best place to buy all the parts needed to do that?
audtatious
You could always replace the motor to something else. I've seen the VQ35 retrofitted into a Sentra but it was a later generation.
What's your budget?
nastynate
Car: 1993 sentra se
Don't really have a budget but I dont wanna over spend. I want a bigger motor than the little stock 1.6
audtatious
Probably the easiest upgrade would be a SR20 but I will have to let the Sentra guys answer that one. I've not owned a Sentra since '96 and it was a stocker.
I'll shoot a msg to one of the Sentra dudes to get their perspective.
nastynate
Car: 1993 sentra se
Thanks a lot. I appreciate it. If you could find out how hard it would be to do also if I need to modify anything for it to fit
audtatious
You may want to do a search as well as there is actually quite a bit of information on the site like this thread:
post6341556.html?hilit=sentra%20sr20#p6341556
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
In order to put a SR20 into the SE, you will need all the drivetrain parts from a SE-R for this to work. As I have always said, if you wish to go that route, it is easier to sell your SE and buy a SE-R.
audtatious
^^^ the man who knows
nastynate
Car: 1993 sentra se
My sentra is overheating. Its a 1993 se. I have changed the thermostat flushed the radiator and the coolant is find the fans are good and the temp switch is new. It still overheats. Anything anyone knows would be helpful
nastynate
Car: 1993 sentra se
Also I Have a buddy wanting to know which motor is better for his sentra. Its the same year as mine only its a XE. He wants either a sr20de or a sr20ve? Any thoughts? Which would be easier?
OneFunB13
Car: 1992 B13 Sentra SE-R
I say if you're gonna swap one anyway, I'd go with a VE, but, you have to have Drivetrain components from an SE-R. The SR20VE are going for around $800, SR16VE, same block different/bore stroke, more aggressive cams, go for around $1600. DE-T motors or JDM 10:1 I think go for around 1k-1200$. At any rate, the most economical route is finding an SE-R. :)
Slute
Car: 91 Nissan Sentra SER/GTIR
not trying to ruin your thread with a sale but if you are interested, im selling my 91 ser all mechanical and steering new with receipts to prove it. also with car or after car is sold, i have gtir pulsar motor (top mount det) which had been in vehicle, with awd n14 rear clip and awd trans.....
