homeslicej2 »
https://forums.nicoclub.com/homeslicej2-u54419.html
Wed Sep 12, 2007 3:05 am
First things to start off with are get your tires balanced and have the wheels checked for dents, bends, etc. If it persists, check and replace as necessary, tie rod ends, T/C rods or bushings, ball joints, heck even your struts/springs could be messed up/loose/blown, but those would probably do it all the time. You could also have some sort of frame damage. If you ever have an issue with vibration or pulling, check your tires (including tire pressure) and suspension components first.
