seattlejoe »
https://forums.nicoclub.com/seattlejoe-u17529.html
Fri Jun 25, 2004 9:09 am
Hello, The rear shocks on my 1993 Q45 need replacing. No local parts houses stock the shock. Any recommendations on where to order them? Also, I appears that it is a simple installation: remove shock/spring assembly, use spring-compresser tool to compress spring, install new shock, and re-install shock/spring assembly. It appears that this has nothing to do with rear wheel alignment, so the local repair shops are doing a "profit center add-on,", e.g., quoting $880 for the job. Any advise about procuring the shocks and installation would be greatly appreciated. Thanks, Joe
