1993 Q45 rear shock replacement
seattlejoe
Hello, The rear shocks on my 1993 Q45 need replacing. No local parts houses stock the shock. Any recommendations on where to order them? Also, I appears that it is a simple installation: remove shock/spring assembly, use spring-compresser tool to compress spring, install new shock, and re-install shock/spring assembly. It appears that this has nothing to do with rear wheel alignment, so the local repair shops are doing a "profit center add-on,", e.g., quoting $880 for the job. Any advise about procuring the shocks and installation would be greatly appreciated. Thanks, Joe
Exar-Kun
Car: 2005 350Z
880 for the job I assume includes shocks, did you try finding shocks, and I would repalce them all around...chances are if everyones quoting you 800 dollars...there's a reason.....
I'm not sure, but I think some q45's had automativally adjusting dampers.. and I know nothing on a Q is cheap.take a look at tire rack for some kyb gr-2 struts and shocks and see how much they are, again I would like to see you replace them all around with the same valved shock, othwerise it'll upset your handling balance a bit.-chet
szh
Car: 2018 Tesla Model 3.
Hi, Joe.
Please also do a search in the Infiniti General forum - lots of good information there on shocks and replacement! It is DIY if you are facile with automotive things to do with your car.
Best Q45 shocks (for first-gen Q, that is) are Tokico Blues, available at Southwest Autoworks (see their ad to the left here). The original Infiniti shocks were OEM from Tokico (Tokico Blacks). They are a bit softer, and the Blues are more recommended.
As also mentioned by Chet, if you have a Q45A model, the "shocks" are adaptive and need a different kind of fix. Contact "Texasoil" (one of the NICO members) for more info - he is able to recharge these Nitrogen-filled units to get the original A performance.
Z
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
Depending on the miles, you may want to have the bushings looked at as well.
