1993 Q45 FUEL INJECTOR REBUILD
SUB ZERO CAR FANATIC
Car: 1993 Infiniti Q45 ( SOLD)
1997 Cadillac Deville Concourse
1998 Cadillac Seville STS
2009 Infiniti QX56 LE
Anyone here know where i can buy parts for fuel injectors? I need pintle caps,possibly screens too. Any info would be greatly appreciated. thanks alot, SUBZERO
Q45tech
No help on parts since they were assembled in Japan [Bosch Japan not Bosch USA].
However as a side note we are now seeing 94 and later injector failures when Atlanta cars are taken out of state to Ethanol areas for vacations etc.
2 so far this Summer, they made it back from NY, NJ,/PA on 6 and 7 cylinders."Emulsified water in the fuel can have several negative effects. Water displaces gasoline, which lubricates the fuel pump. Water pits and corrodes the plated metal surfaces causing premature wear on the fuel pump. Water reacts with various components in the fuel and forms acids, which corrode the fuel injector tips as well. Water/gas emulsions were tested by the SAE with ethanol, and they eat the plating off the pump’s internal moving surfaces. (SAE 2005-01-2196, Rovai, Tanaka, Sinatora)"
http://www.lindertech.com/reconinj.htmh ... je....aspx
