1993 Pathfinder power steering belt and pump
torollout
The power steering belt is loose on my pathfinder but I seem to not be able to find the screw on the power steering pump to adjust the tension of the belt. Any diagrams or pictures of where this should be?
Thanks
Modified by torollout at 8:00 PM 4/17/2007
88pathoffroad
Car: 1988 Nissan Pathfinder XE V6
It's fairly obvious if you get down there and look with a flashlight. The adjuster is on the left side of the pump as viewed from the front. Try removing your slidplate(if so equipped) and get a look from underneath.
