1993 nissan sentra. big rattling noises when i turn on A/C
infii30guy
hi
i have a 93 nissan sentra with 130K miles. it runs pretty smoothly.
fan control works only when i put it at '4' (move all the way to right). don't know it stopped working at speeds 1,2 and 3.
also when i turn on A/C, it makes big noise. i feel the A/C coming out of vent though. what could be the issue? some belts gone bad or compressor?
it gives me about 29mpg on mixed highway/local driving. is that normal or bad mpg for this old car?
thanks
Faja
Car: 2009 Nissan Sentra
Most likely your blower resistor is gone. Have that replaced and then see if your A/C still makes noise when you turn it on. Is the noise coming from the dash/vents or the engine?
infii30guy
noise is coming from below the engine. nothing inside blowers.
Faja
See if this helps you diagnose the problem.
http://www.airconditioningforc...0.htm
ABNRML4U
Car: Nissan B13
Good Luck man, I hope everything went well.
nametakennow
Car: '06 MINI Cooper S
Your 29mpg mixed sounds about right.
What sort of noise does the AC make? Could be the compressor.
infii30guy
it makes loud screeching noise. more when i am driving. when i turn on A/C when stopped at signal with engine running, it still makes same noise.
nametakennow
Check the accessory belt. Either it's bad or the compressor pulley is locked up, most likely.
