Recently had a behind-the-dash electrical short. A metal bracket had worn into some wires and smoked 'em, the car died and wouldn't start again. I took out the dashboard, repaired the burned wires, and tried to start the engine.
When I turn the key I get the usual beeps and dings. The motor cranks, but won't start. Battery is good. I did notice the fuel pump relay "clicks" rather loudly. It clicks twice per second or so. Click click click click... So long as the key is in the ON position.
Not hearing any kind of "whir" from the fuel pump. That seems a little odd to me.
So now I'm wondering if I have a bad fuel pump, or if the computer needs to be reset. So thought I'd go ahead and post. Any ideas?
