1993 Nissan D21 possible cat problems
development1
Hey,
I have a 1993 Nissan D21 Hardbody Pickup KA24E pickup with 314,000km. I am having trouble driving the truck and I am thinking it is the catalytic converter. When driving it is very hesitant, and lagging especially when going up hill. My bro complained when driving for 30 minutes the cat absolutely stank like sulphur. There is a definite loss of power. Also it heats up quite quick. I have included some pics to help.
Here's the front:
The back:
Here's a video of me tapping the cat:http://tinypic.com/player.php?v=npnm8n&s=4
Tell me what you guys think?
Modified by development1 at 7:48 PM 8/11/2008
WWJD
it sounds hallow. If it is hallow I dont think it would cause your problem. when your on the throtle do you hear a rattle noise from under your truck?
development1
no rattle noise, I hear an exhaust sputter
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Hook a vacuum gauge up, hold RPMs at around 2500-3000, watch to see if gauge drops. The gauge dropping means plugged exhaust.
development1
where do I hook up the exhaust gauge?
Rev_D21
A vacuum gauge can be hooked up on any vacuum line after the throttle plate.
development1
Alright so I replaced the cat, and low and behold my truck still hesitates. It is an intermittent hesitation in all gears, and especially when going up a hill it is VERY hesitant, and has no power. I recently changed the O2 sensor 500km ago. Any ideas?
Rev_D21
Ignition timing?
development1
the truck has 314, 000 km, i was possibly leaning towards clogged injectors?
brt
i have a 1987 d21 to and it is doing the same thing and i cut the cat off and it didnt make a diff. so thats not ur problem im telln u that much and i have tryd wht i tought it was, water in the gas and that didnt work,timeing didnt work pugls, wires, cap,rotor,tbi adjustmets, fuel filter. if u find out whts wrong let me know thanks bret.
have ?'s call me at 785-280-9308
ammoman37
Car: 1990 nissan d21 2wd p/u
Did anyone ever come up with a fix on this? I am having the same problem with my truck and was about to pull my cat off.
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
the easiest way to check for a plugged cat is to pull the o2 sensor and drive around. If any power returns then thats your problem most likely, its very simple. Far as the issues people are describing it sounds like dead cylinders, intermittently because of loose injector connections. Check for any corrosion in there which is quite common and clean them. Also, get an FSM from phatg20.net and read through the troubleshooting guides. peace.
93D21VG30E
Car: 1993 Nissan D21 V6 4x4
Have you checked the distributor and spark plug wires? I have a 93 V6 and had similar problems that this fixed.
Rev_D21
I was doing some searching because my 93 has a bad hesitation at 4k RPM and above. From what I was reading a commong problem could be a coked up EGR valve. I am going to run some seafoam through it this weekend to see if that clears it up a bit. Will keep you posted.
