xmetrix »
https://forums.nicoclub.com/xmetrix-u100501.html
Sat Jul 05, 2008 1:33 am
The reason I said dont fill from up top is because I've seen people pour in the gear oil so fast and once it starts dripping out the fill hole, they plug it up. Gear oil is thick and it takes time to level out and drain if you fill it from the top. If you fill it from the top just let it drain out the side hole until it stops draining. You have your truck on jacks in that pic, make sure you do it when the transmission is semi-level.
