1993 Nissan 300zx NA transmission issues
z32trunkboyz
Car: 1993 Nissan 300ZX NA Z32
Ive got a 1993 Nissan 300zx NA. I'm having transmission issues, when its running cold I can shift perfect, no grabbing or grinding. Now when it gets hot I cant even shift into first gear, and every other gear is tight and a pain in the a** to get into and then sometimes they grind whenever they feel frisky. So question, whats next on my to-do list? Just looking for ideas. NEED URGENT HELP PLEASE!!
Reason: Revise Title
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Title revised and moved to correct forum.
PRO TIP: Use The Correct Title: That means, make sure your title has the topic at hand. Don't title something: "I have a question" or "Small concern" or "strange issues" or "HELP!". Instead title it: "tire tpms question" or "Rear bumper paint issue".
Pablo808
Car: 1995 Nissan 300zx
Hmm, so shifting works fine in cold huh? Does your clutch pedal feel the same? Does it sound noisy in neutral? Burning smell? When the transmission gets hot, do you have the same amount of brake fluid in your reservoir?
