I am having a problem with my 1993 Nissan 2wd pickup. When I turn the ignition to the start position I get a click in my Ignition relay. I can hook up a battery charger/ Jump starter and the pickup will fire right up. I have replaced the starter,battery,and checked the clutch switch. When I turn the ignition to the start position I have 12 volts to the starter but I still get nothing until I hook up the charger. If you could help I would appreciate it . Thanks.
Modified by Vanny at 8:04 PM 5/20/2007
