1993 Nissan 240sx Headlights
Xtremist82
I have a problem with my headlights they dont want to go HIGH BEAM. I thought maybe it was the Switch or a RELAY which do you think. Cause when I cut on the brights there's no indication of them being on in the dash. Thanks if you help.
Soy
Car: '03 Mazdaspeed Protege #295
From what I've read, it looks like your switch might be bad - the one on the tree. If you take it out and clean the connectors, that might fix it.
I'm having a similar problem, except my indicator light comes on, which leads me to believe it's a relay.
In any case, checking the switch is easy - just take off the trim panels on the steering column, then pull the switch out.
