I have had an ongoing problem with failing fuel injectors on my 1993 Maxima (VG30E, 247,000 miles). Two fuel injectors went bad last year and I paid to have them replaced (remanufactured). Another injector (not one of the original two) failed two months later. I replaced it myself with re-manufactured injectors. I have since changed the remaining three with remanufactured injectors. Two of those failed and I replaced those with injectors from a salvage yard (fuel rail still under pressure, injectors in excellent shape). One of those has now failed and I have replaced it. The failed units all show an “open” circuit when checked with a meter. Each time I check an injector and the reading is open, I can replace that injector and the car runs fine. I assume an open reading on my meter indicates that the injector coil has burned into or separated. Does anyone have any ideas on what I should be checking that could cause these injectors to burn out? The car runs too good when it is running to give up on it.
Thanks, Mike
