the injector is new, the correct spark plug is new, the coil works, the plug has fire when pulled out of cylinder and the motor is cranked. when the motor is running it has a miss. when i unhook the other 5 injectors one at a time it runs worse but when i unhook the #2 injector it runs the same. i hooked a noid light to the injector wires and it blinks. i swapped two coils and the same thing no fire on cylinder #2. i just bought the car for 500.00 on sunday and the owner said it has a miss. the car has 155,000 miles and has a build date of 4/93.
[email protected]
