1993 J30 Sunroof Problem
nkawall
Car: 93'Infiniti J30 & 09 Altima Coupe 2.5
Hey guys i have a problem with my sunroof in my 1993 J30...the tilt function works fine but the open/close switch could be bad...when i'm opening it i have to pretty much hold the switch and assist the sunroof when its sliding...if i dont assist it, it sticks and you can still hear the motor going...what could this be?
http://www.cardomain.com/ride/2106414
gr8scott72
Car: 1994 Infiniti J30t
nkawall wrote:Hey guys i have a problem with my sunroof in my 1993 J30...the tilt function works fine but the open/close switch could be bad...when i'm opening it i have to pretty much hold the switch and assist the sunroof when its sliding...if i dont assist it, it sticks and you can still hear the motor going...what could this be?
Very common problem on J30s. The fuzzycat site has a procedure to fix it but it's a whole weekend job.
driverdriver
Car: NICO's longtime resident Canuck!!!
I would hedge a bet your J30 sunroof motor is nearly toast.
A dealer will charge you major $$$ to fix it. Lots of labour.
Its a DIY weekend job.
fourdrinie
Car: 2019 Q50
I believe the sunroof motor change is an easy job...it's located right above the light console above the rear view mirror...just a couple of screws and it pops out...Get one from a junkyard or check out car-parts.com...check out the for sale boards here too.
check out the following link to see what it looks like:zerothread?id=215858
gr8scott72
driverdriver wrote:I would hedge a bet your J30 sunroof motor is nearly toast.
I'd like to take that bet.
I think the motor is fine but it's in need of the repair kit as shown on the fuzzycats site.
gr8scott72
fourdrinie wrote:I believe the sunroof motor change is an easy job...it's located right above the light console above the rear view mirror...just a couple of screws and it pops out...Get one from a junkyard or check out car-parts.com...check out the for sale boards here too.
His motor is fine. It's the cable or clips or something else that is broken. My 93 had the same problem. It is not an easy job. Go the the fuzzycats site and look over the procedure.
