My j30 is suffering from a leaky sunroof.
Water leaks in overhead where the sunroof controls are and at the right front corner of the sonroof (looking up from driver seat).
The sunroof tilts perfectly but does not close or open(as if there was no power). It seems as though the relay has fried out since it is directly where the water drops come down. Water actually comes from the front of the assembly runs toward the middle, then drips down where the manual tilt control (where you insert allen wrench).
I am thinking it is the drain holes as mention before but have no idea how to check or clean them.
