VG30DE »
https://forums.nicoclub.com/vg30de-u59786.html
Thu May 17, 2007 6:16 am
Reason he was asking is that non-OEM alternators and batteries are known to cause problems with the J30.
Check all your fuses, make sure none are loose.
Locate the fuse for the electrical components your having problems with, and double check them.
After that you'll have to check out the wiring diagrams from the service manual, and try to trace down any broken wires.
I'm sure someone who knows a lot more will chime in with better suggestions.
Good luck!
