1993 Infiniti J30 OD Shifts On and Off
TexRodeo
Car: 2018 Nissan Altima SR Special Edition Sedan
82k miles
I have a '93 Infiniti J30 with now 135k miles. The Transmission was rebuilt in December of 2007. I bought this car back in late August of 2008 at like 124k miles. Well this past about a week my OD shifts strange around 40-50MPH. It keeps jumping from OD to 3rd and back again, almost like it cant seem to make up it's mind which gear to pick. I had read on the NICO site that the transmission should be serviced at 30k-40k miles, could this be a possibility? Please advise me further on this matter of what possible things I should or could try, I am On disability and really cant afford Costly repairs. :confused: :ohno: :gotme
Larry Little
1993 Infiniti J30 (Base)
135k Miles
yodawill2000
Car: 94 Infiniti J30
I feel your pain brotha'
Start with checking your TPS.
A search on that here should pull many how too's.
Very simple if you have a consult and cable, but can be done at the TPS with a good ohm meter.
TexRodeo
82k miles
yodawill2000,
Will that cause Shift issues with the OD? I have not gotten and Service engine Light or an A/T Check light illuminated at this point. But I will say with this thing not staying put in OD and shifting back to 3rd, it's eating the hell outta gas much more than it normally does. And that is a b**** with a car that has the natural mileage as the J30 and having to feed it Premium Gas that is really hard on my wallet.
I always thought that the TPS would cause issues with the idle control more so than with the transmission shifts. How would it cause or in what way would a malfunctioning TPS cause this type of shift issues? I am a PC/MAC tech not really an auto mechanic and don't have a great many tools to work on a car as well as I dont have acceess to Consult Code reader, Any Other ideas?
Larry Little
135k Miles
yodawill2000
TexRodeo
82k miles
Yoda,
I appreciate that info. OK now is there a step by step procedure to replace the TPS on a '93 Infiniti J30?
Larry Little
GerryO
Car: 1993 J30t
Pearl White
Black Interior
Here's some information that should prove helpful.
http://home.swipnet.se/e-solutions/IdleTech2.html
yodawill2000
Tex
All you may need is to adjust the TPS.
Not replace.
I did that about a year ago and it solved the problem until a month ago or so.
I think I have a different prob.
GerryO
Car: 1993 J30t
Pearl White
Black Interior
A nice diagram, some descriptions and lists of transmission related inputs and outputs for another vehicle. I'd also include the Brake Pedal and Kick-Down Switches, and the MAF, if it's not covered by the Engine Vacuum Sensor.
An exact pin-point diagnosis of this issue will be golden.
driverdriver
Car: NICO's longtime resident Canuck!!!
Do you know if your transmission rebuild an Aamco style rebuild or an OEM rebuild or a rebuild at a JATCO certified shop?
I know from years of reading posts, that there are differences between transmission rebuilds as well as longevity differences. OEM and JATCO certified rebuilds are the most trouble free.
1994 infiniti j30 190+
Car: 1994 Infiniti J30
1990 Ford Ranger XLT Sport Limited Edition
driverdriver wrote:Aamco style
All Automatics Must Come Out haha basically a crappy job unless you now someone there that will actually do a good rebuild
TexRodeo
82k miles
I am Not Sure How it was rebuilt. I just know itr was done before I purchased the vehicle according to the reciept that was left in the Infiniti Leatherbound Folder in the glovebox. Anyways, I turned the TPS Clockwise and the transmission has started shifting fine. Everything seems to be back to normal. Thanks Yoda, I really appreciate it Buddy. :woot: :dblthumb:
Larry Little
135k miles and all is well again!!!
yodawill2000
Cool Beanz !!
driverdriver
:dblthumb:
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
hah i started reading this and hoped you werent having same problem i encountered. my trans died and it started with an issue similar to this. glad it was just the TPS being off. :bigthumb:
