1993 Infiniti G20 Power Window Trouble
broc5k
So my driver's side power window stopped working the other day, and when I took a closer look it appears the window is off it's track. It's out of the weather stripping and I can't get it back in by hand. So my question is, do I need to remove the door panel to fix this? If so, how do I do it and what else should I do to make sure this doesn't happen again? Thanks ahead of time, I appreciate it.
qship96
Car: 1996 Infiniti Q45
Most likely you need a new window regulator.
broc5k
Ok sounds reasonable, thank you for your reply. By the way, do you or anybody else reading this know where I could find a manual for the 1993 G20? I looked at the list in the sticky that's in this forum and there is pretty much every manual except 93.
qship96
For the g20, the 91-96 model manual will be ok to use for figuring out the window problem- the major differences in the G series occured for 1993.5 model where engine was upgraded to OBD2 specs and other upgrades to interior/exterior happened. Easiest way to tell if yours is a 93 vs 93.5 is the 1993.5 added the passangerside airbag
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Welcome to Nico broc5k
Qship96 is right it is most likely a regulator. You will need to remove the panel and remove the bolts securing the window to the regulator then you will want to inspect the track to see what caused the window to go off the track. This may be caused by a binding regulator or something stuck in the window run track.
Here is an image of what you need to take out to get the door panel off. Here is an image of the setup of what is inside the door
Below is the link for the 94 G20 ESM I don't have 93 sry
94 G20
Check in the BF section for anymore information although the early G20s have very vague manuals. Good luck.
broc5k
Awesome! I will check it out when I get a chance. For the clips in the switch panel, will I need anything in particular or will they just pull right out? Thanks for the diagram, that helps a ton!
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Ideally you should use a tool something like this with a forked tip a flathead screwdriver is not very kind to older body retaining clips and most of the time it tends to destroy them, leading to an increased likelihood of noises.
