brian86t »
https://forums.nicoclub.com/brian86t-u122347.html
Mon Dec 15, 2008 2:05 pm
So... I have a problem which seems slightly unique, but hopefully others have suggestions... as I have run out of ideas:the following have been tested and work: fuel pump pumps gasolineECU tests out at 5 green lights and 5 red lights (all clear signal)coil sparksspark plugs sparkengine turns overbut...the truck won't start... I have absolutely no idea what happened... because it was running, and running great... then it stalled, and will not start again. Does anyone have any ideas? The only modification I have on the truck is a ported and polished head, and as it is right now it ran perfectly before... just it won't anymore. The only ideas I have left both have to do with gas: whether it be bad gas (I filled up about half tank like a half mile before it died) or water in the gas tank (the truck sat for about a year and a half before I replaced the engine, but it ran after I replaced everything...) help!Brian
