ash10hunt »
https://forums.nicoclub.com/ash10hunt-u300701.html
Fri Apr 25, 2025 3:17 pm
So I'm at quite a loss for what's going on with my 93 hard body v6. I had low compression so I spent a few weeks redoing the head gaskets in my free time. I finally got everything reassembled last weekend and went to start the truck with fresh fluids and everything, yet it wouldn't start. It cranked, but it wouldn't start. I sprayed starter fluid in the intake and that got it to sputter. That along with the fuel pump making weird noises led me to believe it was the fuel pump so I replaced that. (I know it's not good to throw parts at it but oh well.) I tried starting it again to no avail before realizing the lines from the fuel filter were swapped. I fixed that and then it stopped even cranking. I turn the key and nothing happens. Here's what I've done to diagnose so far:
- checked all fuses
- charger battery
- tried different battery
- checked ECU for faults, got code 55 (no faults)
- checked out
- checked clutch button thing on floor
- double checked spark plug order
I can't check for spark, compression, or fuel bc nothing turns on, except headlights, interior stuff, etc.
I'm really out of ideas, anything helps.
Thank you
