JoannaC00kies1 »
https://forums.nicoclub.com/joannac00kies1-u190327.html
Thu Nov 03, 2011 9:21 pm
I recently picked up a solid 1993 D21 for $200.00 - has 157k on it. Got a steal of a deal!
The guy I purchased the vehicle from smashed out the ignition to get it to work instead of just replacing it or putting in a push button. He did a hell of a number on the steering column.
It appears all the fuses are still good in the fuse box under the dash - but I don't have Wipers - Heat or Radio - no power to any of them. There's no power going to the switch on the column for the wipers - and it doesn't appear that there is power going to the fuses either. I was wondering if this was a common problem or of it here is another main fuse I should be trying to locate? Or if maybe there is just a short somewhere?
There is also a mysterious little micro pressure switch in the column. its just free floating and I don't know what it went to - but when you press it power through the switch shuts off. Any idea what this might be for?
The left headlight likes to come on too randomly throughout the night - but I traced this to the blinker switch - if you push it a certain way it makes the left light come on. Probably busted from being smashed.
Thanks,
-Cerebralailment
