PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Sat Nov 22, 2014 7:11 am
Welcome to NICO!
Are there any mods to the car?
First things you should look for are:
Bad MAF
Bad O2 sensors (they are probably all carboned up now because its been running so rich anyway)
boost leak somewhere (I'm not sure if your charge piping is slightly under pressure at idle, but if it is, and you have a leak, you'll be leaking metered air)
I'd check the last one first, as it's free.
One thing you can do to help with the poor idle in the meantime if you can't find the boost leak, is to induce a vacuum leak somewhere (via the intake manifold). This will suck in un-metered air and help correct the air fuel ratios. Note- this will also turn into a small boost leak when you are hammering on the car, but shouldn't affect performance too much. Let us know how you make out.
