1993 300zx getting no fuel to engine
kemosahbe
Car: 1993 300ZX
I have a 93 300 zx Convertible that has been sitting for 4 years. I have replaced the fuel, fuel filter, cleaned all fuel lines, and replaced the fuel relay. I cannot get any fuel to the engine. I can't hear the fuel filter start pumping when the key is in the on position. I have pulled every fuse under the drivers side access panel. What am I missing? I am so lost. There must be a reason I cannot get juice to the pump. Any Ideas?
NolimitZ32
Have you checked the fuel pump control unit? or the wiring between the ecu and FPCU
kemosahbe
Car: 1993 300ZX
where is it located?
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
Behind the passenger seat by the Anti lock brake unit.
PAintballa45
Car: 1991 300zx n/a (TT in progress : D) slicktop
how do you check if the fuel pump controller is functional or not? I'm having the same problem
NolimitZ32
Check the FSM there should be a pinout and testing procedure, if not then figure out which wires are inputs and outputs and make sure they are receiving the right signal and giving the fuel pump what it needs.
