I snapped a bolt off the first camshaft bearing while torqueing it down. I've searched all the regular stores (Home Depot, Ace, OSH, Kragen, etc..) and they dont have it. Does anybody know where I can get a new set altogether? I dont want junkyard ones, because that would be redundant - but if I need to, i'll grab _one_ from an old 240 or similar. The specs are as follows:
50mm(1 7/8in) Total Length35mm(1 1/4in) Sleeve Length [From top of bolt head]6.3mm(.232in) Sleeve Diameter
Someone told me it may be of a particular alloy...As for the broken piece in the head, its 1/4in exposed underneath and I think I can twist it loose with a vice grip, and just rotate it out with a needle.
The broken one is the left hole of the removed bearing.
